Nov 19, 2012 #1 J jk kelly Member Joined Nov 12, 2012 Messages 174 the gn i just bought has a little miss in it. i changed the plugs,plug wires and the coil pack and its still there,any suggesstions
Nov 19, 2012 #4 S SFI Cutlass Active Member Joined Jan 2, 2010 Messages 378 Make sure all your mounting bolts to your coil and module bracket are tight.
Nov 19, 2012 #6 B broke broke Joined Feb 22, 2011 Messages 397 do you have a scanmaster or any scan tool?
Nov 20, 2012 #7 T TurboBuRick Moderator Staff member Joined Feb 18, 2006 Messages 10,084 Welcome to TB.com! You did the basics I would say it's time for a compression check. Good Luck... Rick
Nov 21, 2012 #8 R "Reaper" Gone To The Dark Side Joined Nov 22, 2007 Messages 1,011 Go to these two places and READ READ READ'!!!!!!!!! http://www.vortexbuicks-etc.com/ http://gnttype.org/ Shaun
