In a nut shell.....radiator to lower radiator hose....Lower radiator hose to water pump....pump through engine block and heads ......engine block and heads to front of intake manifold t stat /tstat housing.....tstat housing to upper radiator hose. And theres the heater core /heater hose circuit. Also water pump bypass hose to circulate water till t stat opens.
