Guys ,
I need help figuring out a problems that just started with my GN.
I run a WB B2B unit.
The car was running perfect to include idleing very nice. I pulled out of the drive way and not 100 ft from the house the motor begins to stumble badly. Before i can get back the car stalls several times and smells rich.
Plugged the laptop in and i notice that the ECM is commanding any where from 1.6 to 2.5 or more at times INJ DC. Its very eratic jumping up and down. The WB shows a corresponding erratic reading anywhere from 9.5 to 11.1 AF The map is also making big jumps and the Vac gauge is barely making 10in and almost vibrating(15 normal) When it was running right It was right on or abouts 13.0 AF.
At 1st i found plug number 6 fouled, now all are.New plugs went in, killed them before i could figure it out.
I have taken all the fuel out available through the ACT and Coolant correction tables as a experiment . Still idleing rough, the AF went up slightly in to the 12.5 AF but continues to run rough.
When it started to act up , the laptop was not pluged in. No changes had been made for weeks to the car or tuning. Fuel pressure is as previously set and hasnt changed.
Can you give any suggestions? Will the cam sensor cause such a problem?
Help?![Confused :confused: :confused:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f615.png)
Help?
