SignUp Now!I've heard that the oldtimers used to reverse slicks to get a few more runs on worn slicks. I think the reason the ET Streets are directional is the way the tread pattern is designed to channel away water. If you ever run through a puddle (we know that would never happen), you may be in for a wild ride.
i think someone just installed them backwards on accident and had someone call them out and they made that story up.
As I understand it, that is an old trick that still works today on slicks. If you've ever noticed, soft compound tires tend to "feather" after a few runs. If you reverse the direction of the tires, the "feathering" generates more grip for at least a couple of runs or until it wears off and starts feathering in the opposite direction. I've seen this on the BFG Drag radials, so I would *assume* other soft compoudnd radials would do it also. Unlike the MT's and Nittos, the BFG's are not directional so you should be OK if you wanted to turn them around and run them in the opposite direction.
just my 2 cents.![]()
Jpratt, are you trying to show me up with your computer expertise? I am still working on typing with more than one finger and you throw a "link" on me.![]()
