I just pulled my tranny to get the converter restalled and happened to grab my flexplate to see if I could get some fore and aft movement. What I discovered was HOLLY S**T, I've got approx .030-.040 movement. The engine has about 7000 miles and about 30 1/8 mile passes since major rebuild. The only thing that I can think of that would have caused this is converter. I have run two converters on this engine since rebuild. First was the Vigilante multi disc and now the billet 9X11. I had a lot of trouble out of the Vigilante; it wouldn't surprise me if it caused the damage. Would it hurt anything to run as is, or could I get away with just replacing all of the main bearings without removing the crank, providing that the crank still looks good. The oil press is still about the same as it was since I first fired it up.
