exhaust clearance issue
blackdeathtrap
smoking six barrel
I currently have issue with 3 inch exhaust hitting rear and if i raise it it hits upper control arms other then getting new exhaust what are my options im thinking tubular upper rear control and that should solve issue other thoughtls were short piece of flex pipe above rear end what do you guys think
Quick fix = "mesage" it with a hammer
Could you add a hanger (or hangers) that will hold it exactly where you want it? If I remember correctly you just had/did a lot of work to your car so I would guess your motor mounts are newer?
You may be able to push the tail pipes into the muffler a little further to re position the arch , then give them a twist towards the springs.
Bryan
after alot of math and calculations and geometry i sectioned out pieces put heat to it and re bend so not taill pipes are extact the same and minimal hiting on rear end problem solved after 18 hours of work near loss of left eye and burn finger hahaha shes sorted now its off to paint to be ready for atlantic nationals
