I'll give you a little history on why Champion uses steel guides with K line liners. Back in the begining around 1999 the first heads had bronze guides and they must have been a bad batch. The guides couldn't handle the elevates EGT's you see in a turbo application. They fell apart, the pieces went thru the turbo and made a mess.
Steel guides with K line inserts aren't really designed for extended usage like you would see in a street engine. They are designed to be serviced and replaced at regular intervals.
What we did in the past when we still ran Champion heads is to install a good quality silicon bronze type guide something like the ones CV sells. I know at one time Billy Anderson was cutting the tapered end off the guides to maximize the wall thickness also. I never tried this myself and didn't have a problem.
I hope this helps.
Neal
