I have one of those not so great poston 3" DP's which has a leak where the two pieces connect. This is AFTER where the O2 sensor reads.I know this should be corrected, but the question is:
will this help the car to pass emissions or not make a difference either way?
I am about to install 50 lb injectors because the originals at 110,000 miles seem to be leaky and the car is a bit rich.Emissions is not til June and the car passed two years ago no problem.Should I worry about the 50 lb injectors or if I get the proper chip it will be okay. I don't want to weld this leak too soon because when I get a good DP it will be a bitch to get off....
anyones .02 appreciated
Chris
Chris
