The engine only has about 1000 miles on it. It was completely rebuilt by Northeast Turbo. The rebuild included balancing, 3 steel main caps, ARP studs and bolt throughout, stock size forged JE piston, file fit rings, ductile roller cam (208-208) and heavy duty double roller timing chain. The heads are stock iron heads but are O-ringed, ported and polished with oversize S.S. valves. New valve springs, push rods and T&D roller rockers. The intake manifold is port matched and polished. The Throttle body is a 70 mm with a precision plenum and RJC power plate. The injectors are 60lb pen type with custom burned chips. The turbo (which only has about 100 miles on it) is a John Craig 63 series w/ adjustable wastegate actuator. The air induction is a Kenne-Belle with integrated spoiler. The intercooler is a CAS-V2 front mount. The oil saver relocation kit was installed and also Razors alcohol injection system. The ignition is stock with 10mm custom fit plug wires.
