I agree about wrap on a crossover, that would definetely make me concerned about fire hazzard being rear main and a number of other leaks will most probably leak right onto it.
Unfortunetly, we can't all sit together at the dinner table and discuss our knowledge/exp. in person. I don't care how nice or jerky anybody comes across on this message board. I'm just thankful their sharing their knowledge with me. I'm here to learn, and, to post my results and thoughts (once in a while).
Having said that, I confess I haven't done any research on the exhaust wrap, I've not been concerned about it. But now another thought has came into my tiny brain and I'm starting to wonder what the heck am I missing here? Lemme explain
I know for a fact my 84 GN has been in the St. Louis area since new. I also know that it spent most of its life sitting outside (in the rain/snow etc), and has also sat for a few periods of time. I know that the car was never cared for anywhere as good as I care for it now. My car still had the factory up-pipe and down-pipe white insulation wrapped with the factory steel braid hose that had the welded clamps on both ends. I had removed it from the up-pipe to repair a leak (was the result of a poor factory weld evidently). I had removed the dp to install headers, and removed the factory wrap then. Both pipes where in excellent shape. No internal corrosion out of the ordinary, and no external corrosion where the factory wrap/insulation had been (for 22 years). (I don't claim to be a expert on corrosion, but I spend a good deal of time at my job inspecting for corrosion on aircraft, so I know a little bit I suppose). Anyways, So... where does wrapping these parts become an issue? I refuse to believe I'm just lucky. Anybody today looking for a hot air turbo car can find one pretty easy. Whether its ebay, these buick boards, or any # of auto for sale sights, and almost everyone of them that I see, still have the factory white insulation wrap covered with the steel braided hose. My point is, It doesn't exactly look like these "wrapped" exhaust parts are failing after 20+years. I realise I can't see the inside of the pipe when I'm looking at a picture of someone else's engine compt. But still, going off mine, I doubt theirs is much differant than mine. What am I missing here? I'll do a little research. Maybe I can find some postings where people have pictures and justification to say "Look, yes, Header wrap installed on exhaust parts do indeed cause failure!"
Is the factory metal used in our up-pipe,dp, crossover...a much higher grade and quality than some of the aftermarket stuff? Therefore maybe giving some people some bad experiences with header wrap? (I know our crossovers where double layered, making them pretty heavy, I think our dp's are too? I don't think the uppipes are, but don't know)
Any comments would be appreciated. (keep in mind I'm still pretty new to these cars, at least in the depth that I am involved with them now, I should say)
