Experience with 9in Ford assembly ?
Louie L.
Habitual Line Stepper
Staff member
Im looking for anyone here that has experience assembling a Ford 9in. Moser did not press the axle bearings on my New axles. I have some questions what direction or sequence the bearings are installed.
Anyone ?
orig or aftermarket housing?
I have 9in aftermarket,
ON THE AXLE - the axle retainer goes on first, mine doesn't use a axle seal as bearing is sealed type, then the bearing, then the press ring, I put silcone around the outer of the bearing to seal any grease from comming out of the housing,
hope that helps some.
