Please no BS just the truth. I finally got the trans back in the car from the shop and I shifts great except for one small problem. I starts out in second gear unless I pull it down in first or back into nuetral. It has the trans go shift kit in it and it shifts nice and firm. No I am not going to install another shift kit this is the second one! The first one did not work. The trans guy pulled the other shift kit out and installed this one. It shifts fine if I go thru the gears manual. I tossed the spring under the big gov weight and installed a weaker spring under the small weight. The car is a 85 monte carlo with 3.73 gears, 28 inch tall tires. Also the instuctions call for one gold washer under servo small piston and 2 gold washers above it. It only takes a small amount of force on the servo cover before the output shaft will no lond turns. I wonder ifthe band is too tight. Anyone ever have this problems?
I have heard the trans go shift kit will cause this problem. WHY?
What is the fix?
Brian
What is the fix?
Brian
