I have the reciept for the tranny on the car I got in Texas from a guy that lived in Memphis and had the Tranny done at Century Automotive and Trans in Richmond Texas. This was done on 10/3/02.
Just wondering how good the upgrade was and maybe what it is capable of. Thanks in advance.
911 converter
Filter, Trans 2004
Teflon Pump bushing
Bushing, Ext. housing
Sprag, overdrive
Sprag, Low/Rev
#14 Button washer
HP Pres Reg. Valve
Shift Kit 2004-R
Pump washer 2004-R
13 vane pump kit
HP Band Wide, 2004
HP Slide spring
Roller Rear support
H/D Pump Ring
HP 3rd with RED & KOLEE
HP 4th with RED/KOLEE
H.P C.S. Rings
Band Anchor HP
.500 Boost valve
Billit DRM W/C.S.
O/H Kit,RED KOLEEN
Direct Drum,2004
O/D Planet
TCC Solenoid BRF
Thanks in Advance.
911 converter
Filter, Trans 2004
Teflon Pump bushing
Sprag, overdrive
Sprag, Low/Rev
#14 Button washer
HP Pres Reg. Valve
Shift Kit 2004-R
Pump washer 2004-R
13 vane pump kit
HP Band Wide, 2004
HP Slide spring
Roller Rear support
H/D Pump Ring
H.P C.S. Rings
Band Anchor HP
.500 Boost valve
Billit DRM W/C.S.
O/H Kit,RED KOLEEN
Direct Drum,2004
O/D Planet
TCC Solenoid BRF
Thanks in Advance.
