I'm a little concerned that I might hit the 512 gr/sec with the setup I'm planning. I'm wondering what is the largest turbo, injectors and boost number I can run before I hit the 512.
I'm in the process of buying 57 lb inj, TA-62 & MPE intercooler with 3" neck. With the stock turbo @ 20 psi, I have seen as much as 338 gr/sec and average around mid 320s at WOT. I'm sure with the TA-62 @ 20 psi & intercooler neck flowing over twice as much as stock into it that the MAF readings should climb into the 400s. I hope to add P&P stock irons & cam by the spring and the number will definitely go higher.
Has anyone reached the 512 number and was forced to switch to the Extreme chip? what was the setup and power numbers?
Marc
Marc
