Oct 6, 2001 #1 S sweetgn Guest What is the proper way to manually put the extender chip in permanent open loop at idle? I seem to have misplaced that part of the directions. Thanks.
Oct 6, 2001 #2 T TurboBob Resident mad scientist Staff member Joined May 24, 2001 Messages 6,679 Extender open loop idle Usually you should do this after the BLM has learned. With the engine idling, remove the calpak from the ECM this is the SMALL chip-looking thingy. When the check engine lite turns on, replace the calpak. The engine will now idle in open loop even when warmed up. TB
