Extender question
SS_Sean
Pro Bracket
Do the extenders have a rev limiter cut on them? I can't remember and can't seem to find my manual right at the moment.
All depends on how the chip was burned...you can have it set at any rev limit you want...or no rev limit at all...
Okay. Cool. Is it programmable from the car, or do I have to remove and return to have it changed? I ask because I over-rev'd the car on a mis-shift while racing the other night and bent a pushrod or collapsed a lifter. Haven't pulled the valve cover yet, but it's that 'old familiar sound'.
Bob
Bob can you answer this question for Sean? Mike is in the hospital so you can't call Full Throttle at this time.
Hey guy's you can tell what the rev limiter is set to by the number on the chip.
Starting with the first # match them to each option.
Extender Chip part number definition
P (datastream) (inj) X (wastegate) (idle/rev) (theft/valet) (revision)
Datastream id (all have spark advance and pulsewidth for Scanmaster)
W- new high speed with IAC and Cross counts, requires Scanmaster 2.1
Y- old high speed, works with Scanmaster 2.0 and 2.1
Z- Stock, low speed.
Injector
A stock/red-top M 52 lucas
B Greenstripes N 57 Siemens High Impedance
C Bluetop P 55 Siemens or Delphi
D 868 Q 65 lb MSD
E 36 Lucas R 65 Siemens
F 38 MSD S 72 Siemens
G Greentop 803 T 72/75 MSD
H Redstripe U 83 Siemens
J 009 V 84 MSD
K 43 lb Limetop (Lightning) W 96 MSD
L 50 MSD X Custom injector or fuel delivery
Wastegate % low/high gear
1 - 60/50
2 - 70/60
3 - 80/75
4 - 85/80 ß--- about 16 psi with the stock wastegate, good street setting
5 - 90/85
6 - 95/90
7 - 100/95 ß--- Typical race setting, about 19 to 20 psi (stock wastegate)
x - custom wastegate setting
Idle / RevLimit
A 750/6000 Stock cam
B 800/6000 200 – 208 cam
C 850/6200 210 – 218 cam
D 900/6300 Big cam
E 1000/6300 Big cam
F 850/none 200 – 208 cam
G 900/none 210 – 218 cam
H 1000/none Big cam
X Custom
Theft prevention / custom option
0 - no anti-theft or valet provisions
1 - anti-theft + convenience/valet mode
x - custom option / feature
Convenience: can disable anti-theft temporarily, car will drive normally
Programmable valet: can disable anti-theft temporarily, WOT prevented.
Revision – current software/features revision is “F”
You welcome :biggrin:
O ya, I got it, Had a spun bearing on the carrier. Had to pull some rabbits to make it work. ;) But I got it back together. Nice and quiet again.;)
Not the neighbors rabbit I saw lastweek? I got some of the wiring soldered lastnight. I am going to finish tonight I hope and go terrorize the neighbor hood tomorrow night.
