external gate hookup
DCVING 6
I need help with how to run the vacuum lines on my Tial wastegate. The MAF PRO boost sylonoid has two ports, 1 to turbo, 1 to gate. The gate obviously has 2 ports, top and bottom, and the turbo has 1 port on the compressor housing.
:confused: :confused:
I'm scanning my diagram for you and will attempt to attach it to this...
Chuck
Ended up being a little different with the MAF PRO using a wastegate sylonoid similar to the stock setup.
For what its worth, I was told to run as follows:
High boost sylonoid (to turbo) goes to compressor housing.
High boost sylonoid (to wastegate) goes to lower port on wastegate.
The top port on the wastegate remains open.
