I have (3) oil pans available.
1- Hamburger rear sump with external pickup built in and (2) turbo drains built into the sides (one per side). Built in crank scraper, baffles and trap doors. Pan rail is by nature un-even due to the manufacturing method, not terrible but be prepared to apply some RTV to the pan. Very trick piece, used, has never seen an engine failure but has been bottomed out on a couple of times (bottom of the pan is still straight, only scuffed. No cut out in the back for a crossover pipe, back of pan is straight down.
$350
1- Cole fabricated dragster style pan. Would not fit a stock crossmember I'm pretty certain. Has kickout on side so it has pipe plugs in the bottom to install the pan over the studs from through the pan. Like brand new, excellent condition. Has trap door and provisions for windage tray mounting built into the pan. Also external pickup and has turbo return fittings.
$150
1- Dragster pan, essentially the same as above but not quite as nice. Been used but never any engine failures.
$100
$350
$150
$100
