scojack_2001
Livin' Like A Refugee
- May 24, 2001
Hey guys, I need some info on how the external wastegates work. It's not specifically a Buick related question, just a general one.
My best friend has a turbo car (5.0) and we need it to pass inspection. We tried yesterday in Dover and it bombed the low idle HCs. Bad. It was over 1800ppm with a limit of 220...![Eek! :eek: :eek:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f631.png)
He has a external gate on the car. If we took the spring out, will that allow the turbo to NOT build boost? Thereby making the car N/A, for all intents and purposes? Kind of like taking the wastegate rod off on our cars.
Plan is to put a set of stock 19lb. per hour injectors in it and turn the timing way down. Car is running a PMS piggyback controller, but that only kicks in at 2500rpm AND 25% TPS voltage.
Any help or advice appreciated.
ScoJack
ScoJack
