SignUp Now!Originally posted by chrisj
what do you mean boost sensing harness and DS? i am a newbie to turbo buicks and from the shelby turbo dodge realm. thanks for the reply.
can the 86 buick regal ecm be reprogrammed on the fly like the gm turbo sunfire, syclone, or the 749?
on the 749 can you run let's say 4 injectors for a 4 cylinder and then stagger additional injectors with alternative fuel that will operate within different parameters of the other injectors? or is it an all or nothing deal where all the injectors are running off the same numbers from the table? sorry for the questions outside turbobuick it's alittle hard to come by info regarding the 749 ecm. thanks, chris.
can you recommend any sites for the 749 and did you buy a kit or do everything yourself? thanks... this has helped alot
Originally posted by bruce
Can it be?, yes.
But, it takes removing the EPROM socket that's in there. I've never been able to find an reliable adapter to read with any adapter. You need a RomulatorII, and the software from Tunercat to do it.
