Does anyone make doublethick / extra thick valve cover gaskets ? or do I need to glue a pair together ?
I'm using a stock cork gasket between my TA heads and valve covers... and apparently the support rail around the valve covers is hitting the gasket surface on the heads, not allowing the thin VC gaskets to compress enough to seal.
