spross86
- Jan 6, 2015
Hi Guys I am having some problems with the new engine startup.
1986 GN
I have a New fast EFI 2.0 and casper box.
I got from Cal back in 2018 and I am just getting this car done so here we go.
I do not have any spark or injector driver output
Single.
FAST power light on with key
Casper box standby on with key off? Battery drain?
Casper box key on — standby , 12v power and 5v on.
I started with the no start tree.
Casper box and FAST case are both grounded directly to battery ground terminal.
All grounds that go to block and heads also have a jumper to battery
Pin (P) 12v ign. On (yes) when connected to module and when not connected.
Disconnected 14 pin
IGN. On 12v to Pin. (C) no test light flash
IGN. On ground pin (C) test light flash’s
And triggers fuel pump and injector.
Pin (3) IGN. On has 4.5v continuous?
It appears that the injector driver is shorted
To voltage.
PC connected to ECM shows crank sensor at 150 revolutions when cranking. but still no spark.
Casper box all 3 led light on
FAST key on power on (yes)
Crank flash’s (red) once
Injector flash’s (Amber) once
Anything I am missing here?
1986 GN
Single.
Disconnected 14 pin
To voltage.
