F/S Reid case Glide with straight cut 180 gear set
chasmat2316
brand new never used Glide built by Select perf , Reid SFI 1pc case , straight cut 180 gear set.
unit new was 4900. asking 3500 firm. bell housing is chevy pattern.
Does the glide have a transbrake and if so what type is it? Thanks
yes it has a brake, it's a select performance unit that sells for 5k new out the door. this is a killer deal 3500 new never used
Can you tell what series it is so that I can look at Select Performance's website to get all of the details? Thanks
I can give you the build # stamped on the case & you can give select a call whats your cell # will text you a few pics
