The cars that run the F.A.S.T. series are no where near factory stock. The Vette has a 511 ci L-88 aluminum headed engine that was dynoed @ 650 fwhp. Another of the fastest cars, a Hemi Road Runner clone, has a 498 ci Hemi with @ 615 at the wheels and 14.0:1. To quote the owner, "It's basically a Super Stock motor". I was reading articles in Hot Rod (Dec. 06 and Jan 07 issues) about them today. The rules allow unlimited displacement increases and other internal modifications within the limits of a stock-appearing block. Largest tire allowed is a G-60 if the car came with them, otherwise it is a G-70 on 6 inch wide rims. They allow basic suspension mods, shocks, springs, bushings, snubbers, and clamped springs but no bolt on traction devices. It also has a catagory that allows parts as long as they appear correct for that year, make, and model.
The Jan issue had the Vette, the RR, and a Stage 1 GS facing off on slicks. The GS was not a normal F.A.S.T. racer. Infact the article said that it was the first time that car had been on the track. They were bashing the Buick about having T/A aluminum heads which would not be allowed in the series. The Buick was the slowest of the three but IIRC it still pulled some high 10's and as far as I know it did it with the stock displacement, un-stroked 455. It did dyno highest out of the three but out wieghed the Vette by around 800 lbs.
There is a factory stock class as well with a lot stricter rules but the fastest cars in that class are 11.70's-11.90's.
I think a stroked 4.1 with a carefully sorted combo and GNX suspension could be very competative. The series requires bias ply tires but I've always heard they could hook better than stock radials. The only real problem I see is the same as at many car shows we go to. It is only open to '55 to '74 muscle cars. We are black sheeps again. baa.....baa
:biggrin:
