Before I post my results, I want to add that I was checking things out after the inspection and noticed I had a Code 51 showing up the scanmaster. I forgot to reset the ECM after unplugging the Direct Scan cable. This was while the car was running.
Mods are in my sig. I did also notice looking at the trans plus I had the setting set for Rich Idle. Don't know if this would affect anything.
Here are my results:
High Speed Emission Results (25 MPH)
RPM: 1965
--------------------Standard------Current Reading ---------Result
HC(PPM)--------------148----------------77----------------Pass
CO(%)----------------0.94---------------2.53--------------Fail
CO2(%)----------------------------------13.2
02(5)-------------------------------------0.1
NOx(ppm)-------------1047---------------23.7--------------Pass
Dilution(%)------------>6-----------------15.7
Low Speed Emission Results( 15 MPH)
RPM: 2071
HC(PPM)--------------152----------------77----------------Pass
CO(%)----------------0.86---------------1.84--------------Fail
CO2(%)----------------------------------13.6
NOx(ppm)-------------1146---------------320--------------Pass
Dilution(%)------------>6-----------------15.4
What do you guys think? I lowered my fuel pressure from 45 (Line off) to 39-40 lbs. Set the trans plus to a regular 3 inch setting from a Rich Idle setting. Reset the ECM and no more codes showing up. Anything else I should do/check before going back and trying again?
Dannyo
RPM: 1965
RPM: 2071
Dannyo
