I have not been able to pass emissions test in Georgia. The only area that is failing is NOx.
Test Results:
25/25 test Reading Allowed
HC ppm 105 148
CO % .41 .94
NOx 1176 1047
RPM 1185 2500 Max
CO+CO2 14.65 6.0 Min
50/15 test Reading Allowed
HC ppm 121 152
CO % .41 .86
NOx 1517 1146
RPM 1096 2500 Max
I have 42+/- fp on a TT emission chip. Probably a little high. EGR seems free. The EGR filter is a little dirty. It has a fairly new 4 wire O2 sensor. Everything else seems fine. Cat Converter looks new but do not know condition. I was going to measure the pipe temp in front of and behind the converter to see if behind is hotter. A previous test came close to passing and all I did was put fresh 93 octane gas and some alcohol in fuel tank. One of NOx passed and the 25 mph failed but that was with a TT street chip installed. I appreciate any help.
Test Results:
HC ppm 105 148
CO % .41 .94
NOx 1176 1047
RPM 1185 2500 Max
HC ppm 121 152
CO % .41 .86
NOx 1517 1146
RPM 1096 2500 Max
