T TKMBUICK New Member Joined Feb 27, 2004 Apr 8, 2010 #1 Which relay on the driver side fender is the fan relay there are two that look the same how do I no which one it is???
T TurboBuRick Moderator Staff member Joined Feb 18, 2006 Apr 8, 2010 #2 Both. One is for high speed and the other is low. One (low speed) is ecm controlled and the other (high speed) is triggereg by a sensor.
T TKMBUICK New Member Joined Feb 27, 2004 Apr 8, 2010 #3 Ok here's the deal my is't working and I bought a new relay for it now do I need two???
T TurboBuRick Moderator Staff member Joined Feb 18, 2006 Apr 8, 2010 #4 No phun intended but the real way is to test a few things to determine what the real problem is. Do you have the means to make a jumper wire? Just a small piece with the ends stripped.
B bmackinnon Active Member Joined Feb 24, 2005 Apr 8, 2010 #5 Assuming you meant my FAN isn't working, you need to troubleshoot it to figure out why... likely a simple relay replacement won't fix it... here is a site that offers a pretty good troubleshooting guide: Vortex Turbo Buick Performance click 'troubleshooting', then 'fan circuitry' .... that should get you figured out...
