RmvBfrFlght
- Sep 28, 2007
Do i need to disconnect the 3wire plug leading to the resistor before i run a wire to the battery??
No need to, and doing so would also open the ground for the fan motor. Don't even need to key-on, just open the hood and run the wire from battery + to each end of the resistor (one at a time).
Also what u call the (fan power wire) comes from a switch i have inside the car & i believe i have it connected to the bottom DS of the resistor. should it be moved to the top of the resistor for hi speed power supply?
This is not the correct way of doing it. The switch should ground the minus side of the relay coil. So that power flows through the relay, not the switch. Doing it this way is a fire hazard, I would remove it.
RemoveBeforeFlight
