If you ground the green wire on top of the intake, thats the high speed fan temp sensor. What that does is run the high speed fan. Just like when you turnon the AC.
If you leave that wire grounded, when you shut the ignition off, it runs the fan for 10-15 minutes then turns it off automatically so it doesnt drain the battery.
Very easy to do with minimal splicing.
