Originally posted by HighPSI
Timing is timing, and pulse width is pulse width regardless what computer is sending the signal. Perhaps, Lonnie or DFI guy could explain.
Cal,
I am not sure I can explain it. It seems to me that the Gen7 WBO2 works to correct much faster and more accurite than the FAST. I HAVE NO PROOF OF THIS. I have noticed with the FAST the closer you get to 0 correction the more power you tend to make. I have tuned the same car with the Gen7 and had similar power as the FAST at 1-2% and the Gen7 at 10-12% correction and ofcourse the closer I was to 0 even more power was made. The FAST seems to be affected more by the swing of the 02 as the fueling changes seem to be slower to me allowing the actual AF to be more off the target. I have had a FAST that would be pig rich in hi gear and when you started working the VE table to get it close then WOW it would be lean accross the board. I have never seen this with the Gen7. Same with timing. I set the base timing with the Gen7 and what the screen says I have with a very stable timing mark when checked with a timing light. I have seen the FAST after the timing was set then checked with a timing light the mark would be moving all over the place. In my opinion from what I have seen I think the Gen7 has a more accrite fuel delivery with more stable timing. Again I have no proof other than my observation. I also have been able to get the cylinder EGT balance much closer than I could with a FAST. In Chris Lyons case we were able to balance within 30deg in 3 pulls on the dyno making even a little more TQ & HP. I also see small gains with the injection timing v/s Intake valve timing. Like I said these are my observations I have no rock solid proof. It would neat to do both systems on the same car to see if they are both the same or if one can really edge out the other. I dont know if there can be a clear winner. If a engine is in tune it does not matter. Like I said earlier I know the Gen7 much better than I know the FAST. So ofcourse I am going to get better results from a Gen7.
