fast adaptor pin help
tdd
not sure if pin was originally hooked up or not but pin 8 on Gn side ,not hooked up on pink pin 5 on xfi side any help appreciated
pin A8 ecm is serial data for scanmaster . you would'nt need that with XFi,
no clue on pin 5 out you'd have to open box and follow trace on the board to see where it went but theres no reason for every pin to have a wire as the stock ecm had several unused pins
maybe John casper (gnvenom) will chime in as he built the box
got it that looked at my buddy's car,its not used, thx for reply much appreciated
It's normally removed when someone installs an eDash
Sent from my SM-N960U1 using Tapatalk
  • Like
Reactions: tdd
