I bought a adapter to connect my FAST computer to my stock wire harness. By the way, I have a 95 Mustang with TT and 55lb injectors. When I turn the key to ignition, the fan come on. Then I crank the car, the fan cut off and never come back on regardless what temp. that I set it on. Is ther a way to correct this? or do I need to run a separate relay and run the trigger wire to it?
Thanks, Robert
Thanks, Robert
