DOHC Vobra
- Mar 11, 2002
Shane,
Thanks for your reply... you and chuck must be long lost twins or something, he sent me an email with almost the exact same list of things! LOL!
Anyway, First, I probably should have clarified, this is not a Wide Band option FAST, I'm using a DIY wb to monitor AFR, so theoretically, none of the closed loop stuff should apply to me, right?
Chuck agrees, I need more timing, and as you both said, I think this will help with idle.
I've never messed with the timing trim table, but will definitely mess with that... as you said, it may help with the fan situation.
I'm guessing that the correction limits etc. won't make any difference since I don't have the wb option.
Thanks again Shane!
Best,
Justin
Thanks again Shane!
Best,
Justin
Originally posted by NoSlix
Justin,
Some things jump out at me about your program.
1. You don't have enough timing at the idle cells in my opinion. I usually bump this up to 30 or so. This in itself will lean the idle mixture out.
2. No timing trim at idle- timing trim helps to stabilize the idle much like the factory ecm does by adding or taking out timing based on how far away from your programmed idle it's running at a given time. Timing trim will help with the fan turn on.
3. closed loop parameters-
a. you don't have the wideband enabled(this may be by your design)
b. even if it was enabled you're turning it on at 7350 and turning it off at 7350 making it innefective
c. min operating temp for closed loop is too low
d. delays are too long
e. gain is too much
f. step is too much
4. Correction limits- you've got some neg numbers in the + side and + in the negative side
I'd be happy to send you an example of how I generally set these up, if you'd like. Others might set them up differently.
