DOHC Vobra
- Mar 11, 2002
I'm wondering if anyone out there has used a GM 3 bar map sensor with a FAST system. I recently switched from my 2 bar sensor that came with my FAST to a 3 bar sensor purchased from GM. It's the one that was used on the Turbo TA's, GM Part number 12223861 (old part number 16040749). The connector had to be very slightly modified to use.
When I connected it to the FAST all appeared to be well, 99-100kpa with the engine off, and about 29 at idle (the same as what my 2 bar reads).
Now, tuning this thing is a whole other deal. I've had lots of problems getting the car to run correctly now that I'm using the 3-bar. I made a table that VERY closely mapped the 2 bar values into the 3 bar table. The car fired up VERY rich, and stumbled a whole lot.
First, I'm wondering, maybe that MAP sensor is incompatible. Second, are there some huge changes that are required when switching from a 2 to 3 bar sensor?
Any help is greatly appreciated!
Justin
Justin
