Okay... this is going to sound weird but hopefully someone has come across the problem before and can help. So I start the car and get the fast all sync'd up by hitting F2. I hit f9 to view my dashboard and the map sensor shows -0.8psi at idle. I open my Base Spark Table which is MAP vs RPM. Well the little bubble is on 119KPA and halfway in between the 500 and 1000 rpm mark like it should be. Well I go to open my fuel curve (volumetric efficiency) and I notice that the little bubble is sitting all the way down at 1kpa and in between 500 to 1000rpm. What the heck?! How are the two not matching? Is there a setting that I've inadvertently hit? Oh btw, the car now does not want to spool on the line. It hits 0psi and just sits there like a bump on a log. Any help would be greatly appreciated. I'm lost.
