P
PureEvil
Guest
Just picked up my FAST system with the stand alone universal harness. Car is a 95 LT1 w/optispark..
The factory computer and wiring has been gutted. There are no wires going to the ignition control module anymore.
Im having some problems wiring up the optispark/ignition control module and MSD box all together with the FAST.
Here is what I have:
PIN K3 A: Tan/Black to Coil Driver....
There are 2 wires in question off the Ignition Module:
WHITE=Ignition Control Wire
White/Black=Coil Driver
Not sure which im supossed to use...
I sneaked a peak at the FASTTRACK splice in harness and they tap into the white ignition control wire, not the white/black coil driver wire.
PIN J3 B: Brown/White to DistA Red/Black (Low Res Signal)
PIN K2 C: Not Used
PIN J2 D: Black/White to Dist D Pink/Black(Ref Low)
I guess I do NOT need to use any High Res signal wires here??..
Now to the Igniton Control Module
There are 4 wires:
White(Ign Control)
Black(ground)
White/Black(Coil Driver)
Pink/Black??
I am clueless on where to connect these wires.
From my msd box I have the black and orange going to my coil, and the red to 12v ignition.
Where does the white wire connect to in this system?
Any help would be muuuch appreciated.. I hope the information provided is sufficient for you to understand what im trying to do.
Thanks!
Russ
1995 TransAm
PIN K2 C: Not Used
There are 4 wires:
White(Ign Control)
Black(ground)
Pink/Black??
Thanks!
Russ
1995 TransAm
