The edash will display oil psi, fuel psi, air fuel ratio, mph, mpg, h2o temp, air temp, and many other things you normally display on a gauge. It will also allow you to switch between tunes and change the 2-step. You can also adjust the tcc lockup, adaptive learning, etc..
Sent from my SAMSUNG-SM-N910A using Tapatalk
