Previous ignition problems were solved by going to a '93 TFI Distributor (vice 94-95 remote TFI)
A little throttle blade increase and working the TPS to read 14 instead of previous 16 keeps a steady idle at 950-1000. TPS still maxes out at 90.
- 1st problem: IAC (or something) wont keep up when trying to drop back to idle from higher revs. Takes a little throttle work to keep it from dying then before it re-stabilizes.
- 2nd bigger problem: Anything above 1500 rpms sends the stock tach swinging sporadically as high as 3000 when FAST dashboard RPMs are much more stable (and lower). Although the engine is not as sporadic as the stock tach, the engine doesnt sound real happy and hunts & seeks when trying to keep 1900 RPM or so. Throttle input to rev above 1500 doesnt really match the rate of engine adjustment (ie throttle changes have an inconsistant effect on raising engine revs. Below 1500 rpms all seems ok.
- 3rd problem: Fuel pump primes fine and seems to be working fine while running (steady FP), but dashboard still shows "0". Is this a big deal to fix or a harmless glitch? Fan seems ok and shows "1" when on.
Sorry so long, but any input is appreciated.
Kirk
Kirk
