Same question, different vehicle with lower EGTs
I'm currently redoing my DP and had planned on moving my WBO2 sensor, so I am following this with much interest.
Currently, my WBO2 is probably 20"-22" from the turbo. I was planning on moving it closer to the turbo, as this seemed too far away to me. (This is on a 4 cyl Toyota, and I'm not seeing temps higher than 1250 in the DP, 4" after the turbo.)
I need to move it anyway because I'm adding a section of flex pipe where the O2 is currently mounted. I can either move it in front of the flex section or after it, and was planning on moving it closer to the turbo. Sounds like if I shoot for something in the 10"-12' range i should be OK. Does this sound right?
Sorry for the novel, but it's hard to get good info when you have an uncommon vehicle/application.
Jeff
