UR50SLO
The Reaper
- Jun 12, 2001
That's the trouble I had..... It would not pick up the tac signal.
Tried it off the XFI.. tried it off the working shift light.. Nada. Nothing. It just sat on low speed.
Tach Signal GMR Pickup, PN 8918 MSD page
http://www.jegs.com/InstallationInstructions/100/121/121-8918.pdf (Instructions)
I put this on and then it was able to pick the signal up. I put a test light on the main power wire going to pump.. .the test light would be dim at idle.. then when I had a friend slowly rev up the engine it would kick on high...
Remove black plug and use a small screw driver to turn the dial inside till it comes on at the RPM you want it to. Mine's at 3200. Under that it's on low speed.
Hope that helps,
Scott
Hope that helps,
Scott
