Dr.drivability
9 second wannabee
- Oct 1, 2005
Anybody have some trick ideas on installing an xfi with a caspers module? Is it best to mount the map sensor under the dash and run a vacuum line to it, or run a harness to the stock location? Can you tap into the hvac system and be accuratate and not take away from hvac door operation? thanks for any ideas, Dave.
