SignUp Now!For the time that was really hauling the mail. With today's converter tech and blowing on it really hard with a fresh stock cam and 1.75 intake rocker ratio on a 9:1 engine 133-134mph would be relatively easy. Maybe i shouldnt throw the easy word around. Tall slick and 3.23's. Need a lot of octane though.Not sure what the fastest stock turbo went, but as far as camshafts though, the stock LC2 cam specs (I believe) are; 192/196 .384"/.408" (w/1.55 rockers) @ 107 LSA. If Cotton trapped that fast with the stock cam, that is very impressive...
A LU converter is only going to be good while locked. The PTC NLU will be pulling from the start to the end of the 1/4mile. Most are locking in 3rd, which is usually at the 1/8 mile mark, losing the first half of the track. The stock cam will need low rpms and cylinder pressure.Brian got a question.. why do you mention the 323's for that recipe Im assuming you would want the 323's because your a fan of NLU and 28" tires im assuming to keep RPM's lower. How about if a LU converter is utilized would you still run the smaller gears opposed to the 3;42's.. Brian i know you are a big fan of the PTC NLU's but a few years ago ..well let me re-phrase that..From what i have read you used to run LU and lock it on 3rd or on a certain MPH i cant recall the thread i read it on but its somehwere obviously an old thread..I also like the explanation of why a PTC NLU is superior because it couples like no other you have tested. But for a street driven car and commuting on the highway with an occasional stop at the track i think a LU is beneficial. So would the 323s be used because of the NLU or do you just prefer the smaller gear ratio.
x2! LOL . . . . that is when Bison makes a piston take a sheaaat . . . . .. . . . and today i learned a new term .. pulling a bison. . .
Why is it that you always make is sound and look easy? LOL......... I never pursued the stock cam myself but with a set of GN1 heads and a custom set of rocker arms i wouldnt be too impressed with less than 133mph with boost under 30psi.
87chrisss said:Brian got a question.. why do you mention the 323's for that recipe Im assuming you would want the 323's because your a fan of NLU and 28" tires im assuming to keep RPM's lower. How about if a LU converter is utilized would you still run the smaller gears opposed to the 3;42's.. Brian i know you are a big fan of the PTC NLU's but a few years ago ..well let me re-phrase that..From what i have read you used to run LU and lock it on 3rd or on a certain MPH i cant recall the thread i read it on but its somehwere obviously an old thread..I also like the explanation of why a PTC NLU is superior because it couples like no other you have tested. But for a street driven car and commuting on the highway with an occasional stop at the track i think a LU is beneficial. So would the 323s be used because of the NLU or do you just prefer the smaller gear ratio.
Jerryl said:x2! LOL . . . . that is when Bison makes a piston take a sheaaat . . . . .
Jim Hicks went 10.40's on a stock longblock.
TE45A, tons of boost, cojones of steel.
Bob
