SignUp Now!Thats how it all starts. Just one more thing to a mostly stock car and then you find yourself hidding money from the wife to buy a bigger this and that. Good luck and it wont stop. Just one more tenth.![]()
Thanks for the info. I am not real familiar with the numbers being thrown around as it pertains to the different size turbos. Let me clear up what I was thinking. My car is a bone stock 16,000 mile beauty. I have already put in the Kirban variable rate springs and have airbags to install. My next step is to replace the original valve springs to bring back the correct seat pressure. I was looking at the Hooker cat back system with Flowmaster mufflers. My friend is a GM mechanic , monday thru friday and hot rodder on sat and sun,for the last 25 years and will do all the work. He specialized in the turbo buicks when they came in for warranty work. Next was an adjustable MAF and fuel pressure reg. A cold air unit as well. I do not know much about the injectors or this power plate. What are my best options??? I was considering changing the turbo as well as the intercooler so I could save the originals. I was leaning toward a stock appearing turbo, with ball-bearings. Would this be a wise move? I also found a nice intercooler with a nice aluminum air box that drops in place of the factory unit. I also need a chip. What plugs and what gap on them???
With good tires would this net 12 flats on the street? I have an 11 sec Max Wedge car as well as a 9 sec Blown 409 chevy. I will not be searching for another tenth after this is completed. I just grab a different set of keys.
I drive this car on nice days and do not want to risk it value in any way except some cosmetics under the hood.
Thanks for all the feedback. I am a high school football coach and I will check back as often as I can. Please keep all your info coming. I am learning a ton. While we are at it, can anyone give me some advise on stoping a 300 pound defensive tackle with a 190 pound guard??? That is tonights goal. The car has to wait until saturday.
Thanks a bunch,
Coach
Thanks a bunch,
Coach
Almost all good ideas.One thing you'll want to think about NOT doing, and that is the flowmaster mufflers. While they sound great on most cars, and arguably are of some benefit on n/a (normally aspirated) engines. They have no place on turbo equiped car, and are for sure a choke point. One turbo equiped cars you should do all that's possible to reduce post turbo backpressure to as near zero as is practical. Flowmasters are the wrong way to go.
I assume when you refer to and "adjustable MAF" that you are referring to the MAF translator/GM maf combo? Good idea!!
Who, what, where, when, how, and why?
witnesses?
r flowmaster mufflers still restictive f one were to have two 3" 40series muffs and 3" torque tech exhaust? im askin this because i have that system on my car and when i ran the car down the track, closed exhaust, and then open exhuast, my time slips were only about .02sec off across the board!
OK TURBO DAVE, What mufflers do I run?? The kit comes with the Hookers. The BB turbo will be next year as will the intercooler. So if I am understanding most of this input, A turbo Tweak chip, bigger MAF, adjustable fuel reg, 60# mototrons,cold air intake, and the cat back. This would do honest what ? low 12's
Coach
Coach
You should be able to easilly hit low 12's with what you have mentioned with good traction.
Chips? I always recommend one of the Extender line, especially if you're easilly capable of exceeding the ECM's 255 limit.
TT chips as I understand are a good choice also.
witnesses?
