WUTSAV8
- May 24, 2001
I took my 86 GN out for a spin today, and the trans started to act up again. But this time I paid more attention to what exactly happens and when.
Here's what I noticed:
1- Light Throttle 2-3 Shift is very weak, almost to the point of being non existent. 1-2 is pretty good. But if you give it more than 1/2+ throttle, the 2-3 shift becomes quite firmer again.
2- Won't go into 3rd randomly. Usually I've noticed it happens when the trans gets hot. I'll be driving along and 2nd will wind up forever and it will not go into 3rd at all. I'll usually try to alternate from D to OD and vice versa, but the only way it "goes away" is when I slow down to a stop and sometimes it will downshift into 1st. Otherwise it's still in 2nd. It was also the first major problem I had with the trans, no 2-3 at WOT.
3- No 3-4 shift unless I let off of the throttle in OD, no matter how light the pedal is being pressed. As soon as I let up, the trans will upshift. Sometimes it acts up in conjunction with problem #2 and wont let me get ito 4th completely unless I vary the shifter position and slow down enough.
This is all intermittent as well. Some days it will shift quite normally and some days it will have a mind of it's own.
What do you gurus think?
