I'm hoping the title got your attention. I've been trying to figure this out this whole summer. Been in talks with Eric Marshall and Bob Bailey and still can't figure it out. I'm going to open it up to you guys to see if I can get some more ideas and hopefully a fix action. When this first happened in May, I thought it was the plugs causing my problems (i installed alky, PLX WB and replaced 5.7 TT chip with 6.1 TT chip). Changed just about everything since then: plugs, wires, coil pack, ign module, battery cable, ecm (3 different units), new 6.1 chip, new powerlogger. Nothing helped. Checked all wiring a thousand times over. Grounds a thousand times. Below is the findings I've tested over and over the past month:
I
1- ran with PL and 6.1 TT chip and runs bad
2- ran w/o pl and with TT chip and runs great
3- ran PL and 5.7 TT chip in another car and runs great
4- ran PL and 6.1 TT chip with AFR correction turned off in chip and runs bad (my car)
All the runs above was with the same ECM.
All grounds checked out fine.
Wiggled every wire possible with no stumble.
During the times with the PL and 6.1 TT chip installed, I got a mal code 42 and 51 and then got mal code 42 and 22 after wide open blasts.
No codes with PL not installed.
I installed a new battery cable (new ECM power cable) just for kicks and no change on how bad it runs.
FYI- when I say it runs bad, it feels like an on/off switch @wot, literally. Also pops/stutters at WOT. Far also wants to slowly die at a stoplight.
Any ideas?
I
Any ideas?
