Fel pro part numbers
1of1547
Village Idiot!!!
Does anyone have the Felpro part numbers for the plenum/intake and vacuum block gaskets? They are included in the head gasket set. But I can't find a parts list for the set.
I've never seen them listed seperately. We get the Plenum gasket from GM. The Vacuum block gasket also comes in the intake manifold gasket kit.
Hope this helps you.
Don't know if this has what you are looking for or not, but here are alot of the numbers:
A/C compressor spacer .030" to align pulleys 14047730 .
AC/Delco Tread Sealer with Teflon 14011040 .
Air Conditioner, delete bracket/pulley (4.3L S-10 pickup) 10118713 .
AC orifice tube assembly GM #3033879
AC Delco #15-5151
AC accumulator GM #2724877
AC Delco # 15-1681 (should be painted black prior to installation)
Belt for use with above - Dayco 5060610 .
Air Dam, Passenger's Side 25525980 .
Air Dam, Driver's Side 25525981 .
Antenna Mast 22038195 .
Applique, shift console Black (GN) 25517561 .
Gray (T) 25528767 .
Belt - serpentine 10105307 (old number 25525518) Kelley-Springfield serpentine belt #635K6
Original Equipment GN/TTA 10105307 (old number 25525518) 21.36mm x 1619.0mm
Factory Replacement TTA 12399983 20.80mm x 1603.0mm
Body Mount Cushions, Lower . .
Position #4 457915 .
Positions #3,5,7 377801 .
GNX (2 per car) 488610 .
Bolt, Rod Cap 25531956 .
Bolt, Main Cap 25517607 .
Bolt, Head -torque to yield Long 25525953 .
Bolt, Head-torque to yield Short 25527831 .
Boost Solenoid 1997157 .
Brace, Alternator accessory 25525338 Discontinued
Brake pressure switch 18018141 .
Brake accumulator 18038507 Old number 18014978
Brake pump & motor 18011279 .
Brake hose, motor to sump 18011403 .
Brake pushrod 18011544 .
Brake Pushrod boot 18011398 .
Brake cover with diaphragm 18M758 Old number 18013293
Brake Power Booster -Vacuum Brakes 1800120 .
Brake Pedal - Vacuum Brakes 1256193 .
Brake - Powermaster rebuild kit 18020067 Has changed to: 18038510 (AC/Delco #18M757)
Brass Brake Combination Valve 25509419 .
Bumper Filler LH Front 12336191 .
Bumper Filler RH Front 12336190 .
Bumper Filler LH Rear 20428396
Bumper Filler RH Rear 20428397
Body Mount Cushions Lower 457915 .
Calpack 16036503 Alternate: 16036504
Cam thrust button w/needle bearings 25532588 .
Cam Sprocket(nylon over teeth) 25523115
Clips, Headliner Trim, Front 20058837
Clips, Headliner Trim, Side .20340201
Clips, Headliner Trim, Rear .20061050
Coil 25533542 .
Coil-to-ignition module screw 25533541 .
Coil-to-ignition module gasket 25526450 .
Coolant Temp Switch(on intake under FPR) .3053190
Coolant recovery reservoir 25525470 .
Crank Shaft, GN/T-Type 12350247 .
Crank Shaft, Turbo Trans-AM (Same as above but has cross drilled main journals) 25535742 .
Crankshaft Balancer Spacer "seal" .030" (max. .060") 25523377 .
Crank Sensor (Complete) 25525667 .
Crank Sensor Bracket 12537113 (AC/Delco #213-280)
Crank Sensor Bolt 12537114 (AC/Delco #213-281)
Crank Sensor 12537109 (AC/Delco #213-292)
1986 ESC Module 16022614 .
1987 ESC Module 16051654 .
Cam Sensor With Drive 25516915 .
Cam Sensor 25518357 .
Cam Sensor Shaft O Ring 1959331 .
Cam Sensor Spacer Shims 1837617 .
Door Striker 20151275 .
EGR filter 10159525 .
EGR Valve 17111570
ECM 1227148 .
Engine, Short Block minus cam 25527476 List $1575 on 6-91 Discontinued
Exhaust Turbo Outlet Pipe (Downpipe) 25526459 .
Exhaust Catalytic Converter 25103338 .
Exhaust "Y" Pipe After Converter 25525383 .
Exhaust Pipe Over Axle LH 25520013 .
Exhaust Pipe Over Axle RH 25520012 .
Exhaust Muffler 25520009 .
Exhaust Tail Pipe LH 25520011 .
Exhaust Tail Pipe RH 25520012 .
Exhaust Manifold LH 25527391 .
Exhaust Manifold RH 25527378 .
Exhaust, Catalytic Converter Hanger 25525381 .
Fan delay relay 25527402 .
Fan Hi and Low Relay 25526984 .
Passenger Side Relay Shroud 25518460 .
Fender well, inner plastic passengers's side (Superceeded PN, original part no longer available) 25526024 .
Flexplate Turbo 81-87 (heavier piston/pins) 25512350 .
Floor mats - black (Regal) Front 22528628/2252629 .
Rear 998842 .
Frame Reinforcement Rods Left 472169 .
Right 472170 .
Front Dash Panel .25520629 (only in blue)
Front Fender LH 25505891 .
Front Fender RH 25505890 .
Fuel pressure regulator, Turbo TA and Somerset 25523720 .
Fuel Rail 25524302 .
Fuel Rail, Feed Line (Pipe Assembly) 25526146 .
Fuel Injector O Ring 10031124 .
Fuel Injector Wire Harness 12060425 .
Fuel Pump Strainer Sock 25055458 .
Fuel Line 'O' Rings Return line at FPR . 22516256
Fuel Line 'O' Rings Feed line at fuel rail 22514722
Fuel Meter Gasket (Between Sender and Tank) 12337247 .
Fuel Pump Relay 10038490 .
Fuel Pump Hanger/Sender 9167390510 .
Gasket Kit, Engine Overhaul (Contains all engine gaskets EXCEPT valve seals) 12328748 .
Gasket Kit, Top End (Includes head gaskets, intake gasket, and valve cover gaskets) 12328759 .
Gasket kit, Front cover (Includes cover gasket, water pump gasket, mechenical fuel pump block off plate gasket. This kit will also fit Buick 3.0L FWD V6) 12337540 .
Gasket, Oil Pan 25521994 .
Gasket, oil pick up screen to block 24501259 .
Gasket, Head gaskets (composite) 25528486 .
Gasket, Head gasket (steel shim) 25524599 .
Gasket, EGR to intake $1.14 25530599 .
Gasket, IAC (round) 25530697 .
Gasket, Upper Plenum to Intake 24502089 .
Gasket, Throttle-Body to Upper Plenum 25517008 .
Gasket, Turbo Inlet bell 25514608 .
Gasket, Vacuum block (top of throttle body) 25536028 .
Gas tank, with TR baffle 22523080 .
Governor (transmission) 8655976 .
Grommet, Pass Side Valve Cover 1264486
Grille Assembly (1987) 25526614
Headlight Bezel LH Chrome 25525091 .
Headlight Bezel RH Chrome 25525090 .
Headlight Bezel LH Black 25525088
Headlight Bezel RH Black 25525089
Heater hoses Inlet 25525213 .
Outlet 25525214 .
To water pump 25525228 .
Water pump Bypass 25525245 .
Hood Insulation Pad 25525977
Idle Air Control (IAC) 25527077
Ignition module 25526449 .
Intake Manifold 25527221 .
Intake, Upper Plenum 25525146 .
Intercooler Air Duct 25526377 .
Intercooler Fan 25526398
Key Lock Cover (Black) 20496885 .
Knock Sensor 10456287
License Plate Frame 14083879 (Flips down & stays)
Lifter Set 5234485-12 .
Low fuel warning assembly 6432974 .
Mass air flow sensor 25007866 Discontinued
MAF Sensor (3"Impalla SS) 25180303 (AC/Delco 1#213-352)
Moldings, Fender well, (Black) .
RH front 25519950 .
LH front 25519951 .
RH rear 24098649 Discontinued
LH rear 20498650 .
Motor Mounts Left 1255273 .
Right 1255274 .
Oil Cooler Adapter 25530885 Discontinued
Oil Cooler Adapter O Ring 25530999 .
Oil Pressure Switch 25036378
Oil Pressure Switch Molded Connector 12085529 (has 3 white wires which need to be spliced in)
Oil Pump, stock 12337732 .
Oxygen Sensor, (Stock) 25162693 (AFS-20)
Oxygen Sensor, (GNX) 25162753 (AFS-22)
Oxygen Sensor, (GM) Heated 25312179 (AFS-74)
Oil Supplement, GM Engine (EOS) 1052367 .
Posi Traction Additive 1052358 .
Posi, Clutch Pack 00231127 .
Positive Battery Cable 12157883 .
PCV valve 25095468 AC# CV893C
PCV grommet 1381487 .
PCV hose 10055808 non turbo part that works-must cut to fit
PCV hose Dayco 87000 3/8" hose with a 90 degree bend that can be trimmed
Pipe - master cylinder to proportioning valve (front) 25519995 .
Power Steering Fluid Reservoir 25531140 .
Power Window Switch- Eschutcheon 20152960 .
Push Rod, Stock 25510025 .
Radiator hose Upper 25525229 .
Lower 25523616 .
Radiator Cap RC27 .
Rear Carrier Pin 26056109
Rear Carrier Pin Bolt 14056196
Rear End Posi Lube(80W-90) 1052271
Rear Lower Control Arms (1LE Camaro ) 10164151 .
Rear Lower Control Arm Bushings (1LE Camaro) 10164152 .
Rear Spoiler Center 25518278 .
Rear Spoiler LH End 25518291 .
Rear Spoiler RH End 25518290 .
Seal, Intake Valve (no seals used on exhaust valves) 25535162 .
Seat Belt guides - F-body enclosed style Right Black 20549668 .
Right Gray 20549798 .
Left Black 20549669 .
Left Gray 20549799 .
Servo Cover (Transmission) 24200798 .
Outer Piston 8678941 .
Inner Piston . .
Shifter Cable 25537476 .
Shifter Applique (Grey) 25528767 .
Shifter Handle (Grey) 22525558 .
Speedometer - 140 mph from Anniversary 84-85 Turbo Riviera (use the faceplate and cluster only) 25076576 .
Starter, Light Weight Unit 10465293 (95+ F-bodies w/v8) AC/Delco # 323-488
Starter, Bolts for Light Weight Unit above 12338064 & 14037733 .
Steering Wheel Cap (Grey) 25531981 .
Steering Whell Cap Allenhead Bolts 25507579 .
Spring, Hood (AC/Delco # 325-271)
3rd Generation Camaro 36mm Lightweight Hollow front sway bar 14094344 .
Bushings for above 14094389 .
Switch, Hobbs GM 25503871 .
Throttle Position Sensor (TPS) 25036663
Timing Chain Tensioner 25532546
Timing Chain Tensioner Spring 1358909
Transmission Dipstick grommet 1259475 .
Transmission Valve Body Separator Plate 8657309 .
T-Top molding strip - RH
20066040 .
T-Top molding strip - LH 20066041 .
T-Top weatherstrip - RH 20211820 .
T-Top weatherstrip - LH 20211821 .
T-Top door weatherstrip - RH 20201220 .
T-Top door weatherstrip - LH 20201221 .
These five numbres are the inside and outside window felts/weatherstrips. Fasten to the tops of the doors
20674282 r.h. side
20363106 r.h. side
20674283 l.h. side
20363107 l.h. side
00327006 cut to fit at the bottom of each door .
T-Top Center "T" (This is the part that the t-tops fit into) 20674345 .
Tail Light Mounting Gasket 5967657
Top Engine Clean 1#1050002 .
Throttle Valve Cable 25532115 .
Torque Converter Clutch Solenoid 8639900 .
Turbo Inlet Gasket - Rivera 1261269 .
Turbo oil drain gasket 25537227 .
Turbo to downpipe seal 1262500 .
Turbo center housing rotating assembly 25527601 .
Vacuum Block Assembly (TTA) 25536304
Vacuum Check Valve (one way) 14047619 .
Vacuum Check Valve HVAC/Cruise 14056648
Valve, Check 25525315 .
Valve Stem Umbrella Seal Kit 12511890 .
Valve Springs, LT1 ~105# Seat Pressure 3927142 .
Valve Cover Grommet (passenger side) 1264486 .
Wastegate - adjustable 25527603 .
Wastegate control hose assembly 25525576 .
Wastegate solenoid 1997157 .
Wastegate solenoid filter 801528 .
Wheel Studs (M12 x 1.5 x 76 ..longer than stock) 22551491 .
Wheel Nut TA Mesh 16" Wheels 10194314 .
Wheel Nut Cap TA Mesh 16" Wheels 10028614 .
Wheel Nut Lock Set 999057 .
Wheel Center Cap (GN) 25525651 .
Wheel Center Cap (T-Type/Turbo T) 25518704 (black centercap with tri shield design).
Window Strip - black bottom of window (RH) 20674283 .
Window Strip - black bottom of window (LH) 20674282 .
Weather Stripping, Outer window Right hand 1#20674282 .
Left hand 1#20674283 .
Weather Stripping, Door left/right 20211180/20211821 .
Windshield Washer reservoir 25506641 .
Non GM parts .
Alternator bearing/ Idler pulley 6203LU .
Axle Housing gasket (rear end cover)
Engine Dynamics (McCord) DT004
FelPro RDS55028-1
McCord 762060
Victor P27857
Larger rear brake cylinders GM 18012305 .
EIS 104432 .
Bendix #WC37644T .
Brake, Speed Bleeders (Russell) front 3958 Summit
rear 3952 .
Brake, PowerMaster (AutoZone) 52-9702 Autozone rebuilds
Brake, Proportioning Valve (Adj.) G3905 Summit
Converter, Vigilante 239028-7 (0#)~32-3500 rpm stall, 7-disc
Coolant Temp Sensor F.A.S.T. 30-7003
Coil Pack, GM/Magnavox(Accel) 140016 .
FelPro Gaskets .
Axle Housing (rear) RDS55028-1
Conversion Set 3.8l CS 8142-4 20 bolt oil pan, VIN A, 7, 9
Distributor Mounting "O" Ring 1-420 .
Timing Cover Packing 1-3986 AF .
Fuel Pump Mounting 1-5181-1 .
Rear Main Bearing Cap Pin 2-10675 S .
Oil Pressure Relief Valve 1-11927 C .
Rear Bearing Cap Seal 2-12708 .
Rear Bearing Cap Pin 2-12708 S .
Water Pump 1-12996-1 .
Oil Pump Suction Flange 1-12999 .
Rear Main Bearing Seal 2-13044 AF .
Timing cover 1-45006-1 .
Oil Pump Cover 1-70032 .
Oil Pan Drain Plug 1-70822 .
Oil pan (Perma-Dry molded rubber) 1-90161 .
Timing Cover Set [Replaces #12337540] TCS45930 Timing cover #95364, O-ring #420, fuel pump #5181,water pump #12996, oil pump cover #70032
Oil Pan Set [Replaces #25521994] OS30521R oil pan #90161, oil pickup #12999
Intake Manifold Set [Replaces #12328760] MS96033 intake manifold #96033, end seals #90911, O-ring #420, vacuum block #94210,RTV#226L
Valve Cover Set VS50156C .
ROL Oil Pan Set (cork) 0S5755 .
Felpro Gaskets Exhaust 1400 .
Felpro Gaskets Intake 1200 .
Felpro Gaskets Head (3.8) 1000 .
Felpro Gaskets Head (4.1) 1026 .
Felpro Gaskets Head (Wire-loc) 1007 .
Main seal kit BS40613 .
Head Gasket set - for vin 7 3.8L HS 9441 B .
water outlet "O" ring 1-427 .
Head gasket 2-9441 B .
Valve Cover 2-50156 .
Throttle Body 1-60654 .
Throttle Body 1-60656 .
Valve Stem seal (VITON) 6-70817 .
EGR 1-72635 .
Fuel Feed Seal 4-90457 .
Fuel Return "O" Ring seal 4-90467 .
Exhaust Manifold 2-90508 .
Oil Drain Connector 1-90587 .
"O" Ring Fuel Injector seal 7-92588 .
Intake Manifold Plenum 1-93332 .
Oil Cooler 1-93378 .
Vacuum block 1-93979 .
Turbo Exhaust Seal 1-60755 .
Clevite Bearings (See Note 1) .
Cam Bearings SH1376S-XX .
Rod Bearings CB1398H-XX .
Main Bearings MS960H-XX .
Line Locks .
TCI 861700 .
B&M 46000 .
Hurst 1745000 .
PowerMaster units/rebuilds
AC-Delco/Durastop 18M581 Note: Durastop line products may list for a cheaper price
AC-Delco 174-698
Cardone Turbo Regal 52-9702 (038996) Note: Second part number in parentheses might be Autozone stock number
Cardone Full size wagon 52-9700 (038995) Only reservoir is different - can exchange with one from old unit)
Cardone service center phone number (800) 777 4780
Prior 6700501
Raybestos (New unit) MC390047
Raybestos RPB650357
Wagner 579702
VDO 2 1/16" Electric Gauges .
Water Temp Gauge 310039 .
Water Temp Sender 323095 .
Oil Pressure Gauge (80psi) 350040 .
Oil Pressure Sender 360003 .
Oil pressure sending unit (like used on the GNX) Stewart-Warner F-279B .
Cyberdyne Air/Fuel gauge 7009 .
O2 sensor - 3 wire - F.A.S.T 30-7001
Manifold Air Temperature Sensor - F.A.S.T 30-7004
Pistons, TRW Forged (See Note 1) L2481F-XX .
Piston Rings, Sealed Power, Plasma Molly, FILE TO FIT (See Note 1) R-10437-XXX .
Piston Rings, Sealed Power, Molly, NON-FILE TO FIT (See Note 1) E-434K-XXX .
Piston Rings, Gapless Total Seals ( standard ) TSR-2165TS1 .
Piston Rings, Gapless Total Seals ( 0.030 over ) TSR-2165030TS1 .
HD Billet Servo Slide Assembly (SSA) 200-4R 20040 Fairbanks Racing Products
Rocker Arm, Shaft HD RS-624 (Sealed Power)
Rocker Arm, Shaft HD Assembly RA-1068H (Sealed Power)
Thermostat 160 (Motorcraft ) RT-350
Thermostat 160 (O; Rielly) 13356
Thermostat Gasket 25132
Valve, Springs: .
OD(in.) Closed# Open# Rate(#/in.) Part number
1.20 80 200 267 VS677
1.23 85 230 295 VS1615
1.264 105 277 350 VS739R
1.24 80 200 267 CC 979
1.23 91 229 307 CC 980
1.25 105 295 423 CC 981
Federal Mogul and Comp Cams numbers. CC979 has no internal dampers.
Posi Unit, Moroso Brute Strength 83030 .
Timing Chain, Cloyes True Roller 93134 .
Higher Capacity Oil Filters .
AC PF-52 .
Fram 3980 .
Mr Gasket Universal Drain Plug Kit GKT 4470 .
O2 Sensors, Bosch One wire 0-258-002-019 .
Three wire 0-258-003-106 .
Fuel Injector O rings (Also for regulator) SK1 RN7 .
Fuel Injector, "Blue Tops" 0-280-150-967 .
K & N Filters Stock Replacement style RE-0910 .
Main Stud kit for Buick V6 Stage 1 & 2, 2-Bolt Main, includes nuts and washers. 123-5401 ARP
Valve cover vent 62-1160 .
B&M Transkit for THM200-4R 35229 .
B&M Supercooler (11" x 7") 70255 .
Transmission filter and pan gasket set Fram 1057B .
Relay, 30 amp, for Fuel pump hot wiring, Radio Shack 275-226 .
TCI Filter and Pan Gasket Kit 386500 .
TCI Pro Super 200-4R Overhaul Kit 386800 .
TCI Hardened Input Shaft 384500 .
Coolant Temp Sensor Speed Pro Electronics 30-7003 .
3-wire O2 sensor Speed Pro Electronics 30-7001 .
Manifold Air Temp Sensor Speed Pro Electronics 30-7004 .
TCI TR calibrated valve body (BRF equivalent) 382200 .
Stock Replacement Oil Pump Kit, Melling NAPA# BK601-1311 .
Southside Machine Lift Bars P1313 .
Jacobs Spark plug wires 401290 .
Valves, Intake (TRW) V3124X 1.770"
Valves, Intake (Manley) Severe Duty 11502 1.710"
Valves, Exhaust (Manley) 11503 1.500"
Valves, Intake (Manley) Severe Duty 11504 1.775"
Slicks, Mickey Thompson, 26x10x15 3053 .
__________________
MS 96033
Has the plenum/intake and vacuum block gaskets in the 1 box
FRED
The timing cover is TSC 45930.
The Felpro kit MS 96033 does not come with the plenum gasket. You either have to buy that from GM or Kirban sells them.
Standard makes a Throttle body gasket kit part #2004
