After 21 years, my beloved GN is seeping oil out of the back of the valve cover gaskets. Did I hear someone say the Mobil I synthetic oil will cause problems with cork gaskets?
Anyway, my mechanic wants to use Fel-Pro PermaDry Plus rubber gaskets with a metal insert? He said that these would be the best to use. He wants $69.95 for the gaskets and $350 for the labor?:frown:
Both the Kirbans and Posten catalogs recommend replacing with original cork type gaskets.
Has anyone else used the PermaDry Plus gaskets? Are they worth the extra cost? Is changing the valve cover gaskets that much labor?
I am not very mechanically inclined, so can a novice like me change the valve covers gaskets without fsck'ng something up. I do have access to an Air Force Base Auto Hobby shop.
P.S. Is there anything, besides chrome-plating, that I could do to the valve covers to clean/dress them up?
Thanx...
Thanx...
		 .  The driver's side is easy so do that one first to build your confidence.  It's tricky on the passenger side to maneuver the cover between the a/c box and the heater pipes and you will be sure to knock the gasket out of place at least once, so just practice a couple of times getting the cover on and off before you put the new gasket in place.  A little patience here helps a lot.
