- Aug 1, 2003
does anyone know the thickness of the felpro 1200 gaskets
reason i ask is i got a set of cnc ported heads off the board and the intake surface looked to be milled ,well apparently they are heavily milled for what reason i still dont know to the point that the egr passge holes on the ends are just a hole (no comma shaped depression like im used to seeing)
the previous owner claimed he used stock gaskets which are even taller than the .060 cometics i planned to run
i bolted the heads loose and went to fit the intake with 90633 gasket to square the heads before torqueing them down and the intake wont possibly work with a 90633 gasket , , i have approx .100 -.108 on each side of the intake with the intake sitting on the block (no gasket rubber strips or sealer on block either ) the heads pulled up tight on the dowels
intake is stock never cut
i dont know how much going to steel shims would help
Has any one ever run across this ?
