Fender Lip Rolling Question
SpeedRacerX
A couple of questions...
How does one reattach the wheel well molding trim after the lip is rolled up?
With GNX fender flares, how do they attach if the normal hole locations are now rolled up and away?
Thank you.
Sent from my SAMSUNG-SM-G900A using Tapatalk
I've seen it a couple different ways.
On mine I used shears to cut the mouldings, trimming away the "flat" section, but leaving tabs where the holes are. Then rolled the tabs over to match the rolled fender, and put the screws in like they were originally.
That makes sense now. I wonder if the same process can work with GNX fender flares?
8.5 VECTORS WITH 275/60/15 , no rubs :) This is the tight side too , would need adjustable upper arms to center the rear perfectly !
