limitedv6
Stage 11 in the work's
- May 5, 2007
Brf tranny I picked it up to build a spare for my car after I pulled the pan I found out that someone swapped the valve body. The bolt's were so loose that a couple were in the pan the wiring is gone too I am guessing it has a non lockup valve in it. I can't tell what vb it is the only numbers on the ve are 74 & yag & 4203*d4 the case is a brf $200.00
Underdrive pulley $55.00 shipped
Turbo crank 010-010 I had it checked the machine shop said the rod's will polish out but the mains will need to go 020 $150.00 obo
Stock pistons and ros's with sps rod bolts $60.00
Tranny dust covers (converter cover) $20.00
Stock wastegate $20.00
Stock adj wastegate $30.00
20 bolt oil pan has no tray in it $30.00 obo
Arp head bolts for stock heads used $40.00 obo
Part's that I could take on trade
1026 head gaskets
1000 intake gaskets
plenum and throttle body gaskets
Dutt dls or white racing oil pump
turbo saver I only need the the peice that the filter goes on
m&a valve cover gaskets
Thanks in advance
1026 head gaskets
1000 intake gaskets
Thanks in advance
